Bought Phone from PM, no SIM card.
teridactyl
I bought a Samsung A13 from Public Mobile and was promised a SIM card with the phone. I got the phone but there was no new SIM card with it.
8 REPLIES 8
JS10
Exact same thing happened to me. I filed a ticket, and contacted customer support via https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
They are now sending me a new card for free.
@APALMER12002 wrote:
u should be able activate be yourselves or u can go to telus store
The sales statff at stores won't be able to help with Public Mobile activations. Customers must do the activations themselves.
CountyDownIeUk
I believe  the SIM and phone is supplied  from different suppliers, thus not together. SIM delivery is usually quite  good. But when goes awry.., it never shows. If you need help to obtain a SIM quickly, please feel free to private message me.
APALMER12002
HALIMACS
@teridactyl
Are you certain?
Did you check under the device/ packaging for a small folder which should have contained the credit card sized 3- hole punch out card?
hycm53
Chat with Simon for your order, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
@teridactyl
should have came with it
You can open a ticket with PM support and ask them to send it back to you.  Please open ticket via direct message with your order #
However, if you are existing subscriber, you are  simply move your existing sim card from the old phone to this new one.  You don't really need the sim card other than keep it for future use
If you are going to activate new account, instead of waiting, it could be quicker to simply buy the PM sim card from a Telus or Koodo store instead of wait PM to ship you back, it could take 3 weeks
Submit a ticket with CSA @teridactyl  and let them know, and request one sent to you.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
