Autopay discount not applied on account
lcheng3
An autopay of $2 off /month was part of plan but have not seen on since Feb 2022 since start of plan.  How do I get this corrected?
JL9
What plan do you have? 25 is 1.25 points and 35 is 1.75 points, anything higher is over the 2 autopay you would get. However it isn't applied as a discount right away you have to collect 15 points to get a 15 off bill credit
hairbag1
As of late January, the old Reward program stopped and the new Point program replaced it. Here's some reading to catch up on the details...
https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-Rewards
...before you say it...we all know what you think of the new Points program vs old Rewards !!  😢
darlicious
@lcheng3
Did you activate on or after January 25th 2022? If so you are on the points system and you get 5% back in points instead of the autopay $2 reward.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
dust2dust
If you signed up after later January then you don't get the $2. You would be on the points system.
