Auto Pay by Credit Card no rewards?
wjwcdc0315
My last phone number auto pay can get 2$ reward per month,my new phone numer no rewards,Public change police?
Yummy
If you used to get $2 off for autopay (if you activated before 2022.01.25) and you did NOT switch to points, there is no reason not to get that reward.
Do you see on your account - Payments - Pre-Authorized Payment under Rewards (right-hand side of the screen)?
CountyDownIeUk
When did you activate?
New plans are on Points. 5% of payments. And possibly on 3 x points.
Older plans are on the $ rewards which also included $2 off for auto pay and up to $5 off for loyalty.
Some folks on the $ rewards may have switched over to points.
JL9
What plan did you get? If you are on the 40 plan you get 2 dollars/points back anything higher you'd get more than the 2 and anything lower less. However, if you have recently signed up you should be getting the 3x points promo for a year so for the next year even on a lower plan you would be getting way more than the old rewards ppl anyways.
@wjwcdc0315   Since Jan 25, PM has introduced a new reward program , Public Points.  Anyone joined after Jan 25 will be  on this new rewards program.   With Public Points , there is no more $2 Autopay rewards. Instead , you can 5% back in Public Points. Once you collect enough to 15 Points, you can convert it to $15 Bill Credit
Here are more info of Public Points
https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-Rewards
Alexandf
@wjwcdc0315
no $2 rewards for autopayment , just point rewards.
