11-19-2025 05:31 PM
All numbers dialing out say not in service, call 611, 611 Does not exist, no support
Tried the Chat "online support"
tried changing phone number to no avail.
called telus directly with no avail.
Any tips?
Thank you in advance.
11-19-2025 06:57 PM
support said its a glitch from their end they are now working on it .
11-19-2025 06:31 PM
with your model of phone, although it has VoLTE, it is on the VoLTE whitelist set by PM, so you will need to use 3G for voice. You can also confirm that here:
https://www.publicmobile.ca/en/get-help/articles/volte
Without VoLTE support from PM, you phone might not work very well with voice calls and that could be why you are experiencing voice calls trouble
And Telus is currently refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficient, reality is 1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice (Data is not impacted as your phone has the compatible bands on 4G/5G)
But test your sim card on another phone first to confirm if it is a device issue or if it is account. Preferably test it on an iPhone or Samsung S22 (or later) for more accurate test as those phone have VoLTE support with PM
11-19-2025 06:12 PM
yep - tried other SIMs i nhouse hold - find . on Public mobile. account says its fine in the portal - tried "lock device" unlock device( suspsend/resume) to no avail. i had someone from PM chat with me yesterday but they got awakard not sure why .
11-19-2025 06:04 PM
what phone do you have?
first, Reboot phone and Reset network settings
at the same time, I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
11-19-2025 06:00 PM
the device is not the issue, the SNR. Cell ID , are all correct, coverage, devicem IMEI - its a carrier network block with no support. . "All numbers dialing out say not in service, call 611, 611 Does not exist, no support" if voice returns that audio its connected and authorized and the SYNC level
11-19-2025 05:55 PM
ok but does it show your network at the top of your cell as being Public Mobile ? When you log in to your account can you confirm if the account is active and in good standing ?
11-19-2025 05:36 PM
there is clear single to the operator cell, great SNR, this is clearly an operator issue.
11-19-2025 05:33 PM
@DisabledHuman Do you get any signal on your phone? What is your account status? Can you send text or use Data? Try enabling/disabling Airplane mode.
