Activation
JT242
Good day all,
I signed up for a plan yesterday. But my iPhone 11 is set to a different country and I am unable to download the app to activate the plan. Tried changing the country to Canada, had to cancel apple music sub but now I have to wait until the 28th for the sub to expire. Is there any  way I can activate my eSIM and plan without the app?
Thanks for the help!!
@JT242  Can be more tricky with eSIM then physical sim . But in the case of eSIM you would them scan the QR code from the welcome email with your phone to install . Don’t let it automatically install to the phone during the activation process
JT242
Hi Handy,
Thanks for the reply. Would this solution not register/activate the plan to my friends imei number/phone? Never activated an eSIM before so I am not sure of the activation steps.
Chalupa_Batman
Hi @JT242
Due to your current situation, the only real option is to jailbreak your phone to put apps on it without going through the Apple store. I'm not saying I recommend that, just saying this is the quick fix. However, another option maybe is to do a factory reset on the phone and start a new apple account here in Canada hooked up wit a Canadian Wifi account. You will of course need to back up of your iphone to your PC first. Just my thoughts.
@JT242
Unfortunately you need the app to activate a SIM or eSIM. Not like the good old days where you can activate them on your computer.
@JT242  NO you need the app to activate Change the location to Canada in the App Store itself , or use a friends phone to download app and activate , then you can manage the account on the website from there
