07-21-2019 09:25 AM - edited 01-05-2022 08:22 AM
Hello,
I tried to activate a sim card yesterday that I purchased at Walmart. I picked a phone number (don't remember), no porting. I inputed all the info carefully but when it processed my visa debit card, it was loading for a long time and finally gave me an error message. However, the payment has gone through on my bank account. I didn't receive any emails. When I try login in, it gives me an error. When I click forgot my password, it says: Sorry, we’re unable to verify your email address.
I was able to create an account with same email /password for the community but it's not working for "my account".
I have tried the sim card in the phone and it is asking for a sim card unlock code. I understand my phone is probably locked. I will be calling Virgin to unlock as soon as they open. I'm using an LGG4 phone.
@Moderator_Team Please help! My son is leaving for camp on Wednesday and I'm hoping to have his phone activated by then!
Thank you!
PS: I have sent this message to the moderator and am waiting for a response.
08-28-2019 03:39 AM
07-21-2019 01:16 PM
Yes! These are the steps I took for the LGG4 phone.
1) activated on new number
2) payment processed but gave error
3) sim card was activated properly but no selfserve account was created
4) no confirmation emails sent
5) setup a selfserve account by entering tel number and receiving pin. (https://selfserve.publicmobile.ca/self-registration/)
6) phone worked after entering SIM card unlock code
7) text worked after doing a network reset
😎 data worked after manually inputing proper APN settings / save/ select
What a workout! lol
07-21-2019 01:00 PM
@craftythumbs wrote:It worked! I got the data working by changing the APN settings. I didn't need to do a factory reset! Yay! I have a happy boy with a working phone, text and data...ready for camp!
Thanks to all for your input! Very grateful! 🙂
Great! An LG success story. Thanks for the update. Good to know that they don't all need full resets.
07-21-2019 12:57 PM
07-21-2019 12:44 PM
Some games are saved locally and some through Google profiles.
He could try installing the game on another device while logged in to his Google play. If it syncs then he's is good. If not and a factory reset is needed he should be able to reach that level again in 1/2 the time
07-21-2019 12:42 PM
@craftythumbs wrote:He says it's a game app through google play. He's at level 1417! lol
He says he signed up with his email adress.
When he logs on his computer, he can see his phone files, pictures, and the game folder. However, there's nothing in that folder for him to save.
@craftythumbs Maybe google if there is a way to backup score/level for that specific game with the ability to restore from backup.
07-21-2019 12:41 PM
Does the game require wifi to be able to play? And not just for ads or updates. If so then it's online. The scores are probably on their server in that case. But he should check with them. Maybe he can find a forum for the game and they might know.
07-21-2019 12:39 PM
@craftythumbs just to confirm what happened for future reference:
5) you were able to setup a selfserve account by entering tel number and receiving pin.
I left out the locked phone issue as it was not really a factor in the activation process.
07-21-2019 12:37 PM
07-21-2019 12:35 PM
Try network reset again then enter the pm apn settings.
If that doesn't work then the only solution is the factory reset then adding apn. But network reset plus adding apn usually works.
This is a known LG phone issue.
07-21-2019 12:34 PM
@craftythumbs wrote:Thank you! It worked! I now have access to the "my account".
The only thing left is to get the data working. It would be nice if there was a way to not reset factory settings...since he's scared of loosing his game levels.
@craftythumbs Double check the apn settings to make sure the correct one is selected.
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
07-21-2019 12:30 PM
07-21-2019 12:20 PM
Yeah unfortunately LG's are notorious for having to do full resets.
Is that game online or only on the device? Maybe his score is being held at the source. Maybe there's a way to save that game data.
07-21-2019 12:19 PM
@craftythumbs wrote:Thank you! I was able to unlock the phone by contacting virgin mobile.
Once I entered the sim card, it asked my sim card unlocking code and it managed to get the phone working.
Then, I did a network reset to get the text working.
However, the data isn't working. My son doesn't want to reset the factory settings. He's at level 1000 in a game and doesn't want to risk loosing his levels. lol
I've activated his phone for his 3 week camp...He's currently debating between having 500mb of data or loosing his game levels. Teenager life is hard! lol
I still can't access "my accounts". My email is not recognized.
@craftythumbs Click here to register your selfserve account. If that doesn't work then you need to wait for the moderator to fix it.
07-21-2019 12:17 PM
07-21-2019 11:54 AM - edited 07-21-2019 11:57 AM
@craftythumbs wrote:Hello,
@craftythumbs That charge you see via your online banking is PM's holding charge issued when you enter your payment info during activation. Holding charges can stay in your account for up to 48 hours and may or may not turn into a charge.
SInce the account was not created it suggests that the activation is not complete so it's unlikely that the sim was activated. While waiting for the moderator's response you might want to try the activation again. Try using the browser in privacy/incognito mode. If you get an invalid sim error that means the activation will not be successful.
Calling Virgin to get the unlock code is recommended at this stage.Hopefully the sim card is activated so that you can get the number but I suspect it won't be.
Thank you!
As others have mentioned best to include the sim number and the email that you used during activation to speed up the process. Moderator response times take up to 48 hours so the activation should be resolved before Wednesday. If your plan includes data look up how to reset network settings for that model phone just in case you have issues with data not working once your plan is activated.
Hope this helps!
07-21-2019 10:23 AM
@craftythumbs just a FYI the g4 will require a network settings reset and or a full factory reset to get data working.
Also to you message to mods o would include you sim number and any additional details so they can verify the issue.
The sim might work, any way to test it in your phone?
07-21-2019 09:56 AM
I've been trying to contact virgin to unlock it but their system is down for upgrade....
I haven't tryed the 611 yet since I can't get pass the "input SIM card unlock code" screen.
Once I can unlock it, I will try inserting the sim card again and hopefully I can get it going or at least figure out what the phone number is.
Thanks!
07-21-2019 09:30 AM
@craftythumbs yes get in touch with virgin for the code did you try to phone *611 does it say if your account is active?
