01-25-2021 08:36 PM - edited 01-05-2022 05:00 PM
I have created a new account, activated successfully, account has been billed....no service! Have restarted and reinserted SOM card multiple times.
Son has same phone and public mobile and he has service.
Frustrated!
01-26-2021 07:13 AM - edited 01-26-2021 07:13 AM
Apparently there was an issue causing up to a four hour delay in new number activations. The first I have ever heard of this kind of issue. I'm happy to hear it has fixed itself.
FYI....to address a specific member you can tag them by tapping the "@" key and a box will pop up with the usernames in it or continue to type a name for it to pop up.....
Welcome to Public Mobile and welcome to the community!
01-26-2021 07:06 AM
I think you are correct. It worked after a couple hours.
Thanks
01-26-2021 07:05 AM
There was no porting involved. New phone, new number. But after a couple hours it is working.
Thanks
01-26-2021 07:03 AM
I was not porting. Brand new phone and number.
01-26-2021 07:03 AM
It rectified itself after about 2 hours. Must have been on the other end.
Thanks everyone.
01-25-2021 09:39 PM
@Mackgre wrote:I swapped the Sim cards with my son's phone. His card worked in my new phone. Mine did not work in his. BUT...when I swapped them back, the new SIM worked in the new phone.
HOWEVER...the new phone can make a phone call, but not receive one. Calls from it have "no caller ID". and when I try to call it I hear "not equipped for incoming calls".
@Mackgre Hey, at least we're all making progress... did you port the number from another provider?
If so, it may just be a matter of time to complete the porting process, or try the porting help supplied in my prior post.
01-25-2021 09:39 PM - last edited on 02-03-2021 06:13 PM by Ioana_R
Call the Porting Team at *********to assist with your port.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
01-25-2021 09:38 PM
how long you have activated your account?
there has been couple post about activation issue tonight.. i wonder if server is slow activating new accounts tonight
01-25-2021 09:31 PM
01-25-2021 08:50 PM - last edited on 02-03-2021 06:12 PM by Ioana_R
Also, @Mackgre , try your son's Public Mobile SIM card in your phone. The combination of trying each other's SIM's in the opposite phone will help establish whether it's simply a matter of activation taking time (i.e. if porting?) or if there may be a SIM issue or mobile phone compatibility issue.
If you DID port from another supplier and need help with the porting process, open a ticket for assistance here and type "port request" or call the porting team at **********.
Refer to this link below for more details on the porting process:
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
01-25-2021 08:40 PM - edited 01-25-2021 08:41 PM
Hello @Mackgre - does your SELF SERVE account say ACTIVE?
Great, if so.
Try one or more of the below:
*turn off your phone, leave off for at least 3 minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
EDIT - when did you activate?
01-25-2021 08:39 PM
@Mackgre wrote:I have created a new account, activated successfully, account has been billed....no service! Have restarted and reinserted SOM card multiple times.
Frustrated!
Hello @Mackgre ,
Can you try your SIM in your son's phone just to make sure it is not a phone issue on your end?
IS your phone locked by its previous provider?
Contact your previous provider to unlock it for you.
You will need your imei number dial *#06# to get it.
01-25-2021 08:38 PM - edited 01-25-2021 08:39 PM
Frustrated!
Are you porting a number over? Can you try your SIM card in your son’s phone?
