07-05-2022
08:01 PM
07-05-2022
11:47 PM
computergeek541
Hi All,
I added a US Roaming Add On, but I won't be going for another week. How can I change it so it starts next Wednesday, July 13, 2022, instead of today?
07-05-2022 08:06 PM - edited 07-05-2022 08:07 PM
@sherma_howe wrote:I do see it in my balance so it appears to have been added as it is also showing in the Add-On section. How do I contact the support people. Do I have to exhaust all the "auto" questions before it will connect me with a live person?
Hi @sherma_howe , you can't change the date
But you can open a ticket with PM CS Agent and try to ask them to reverse the purchase. if they agree, they will put the money back to your account, then you can re-buy it next week
You can open ticket with CS Agent at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
07-05-2022 08:02 PM
Contact a CSA and ask to redo your add-on....
07-05-2022 08:03 PM
You would need to contact the support people to have them remove the add-on and credit your account back.
But do you see the amount in your balance? If so then you didn't actually buy it.
07-05-2022 08:05 PM
then Click "Other"
07-05-2022 08:07 PM
So you already had some balance in your account? Did you buy a data roaming add-on? Or talk and/or text? Or all?
Use the link provided earlier.
07-05-2022 08:12 PM
You could pleased your case with the agent and you might get refund.
As you now know, US add-on starts immediately and lasts for 240 hours.
07-05-2022 08:16 PM
Thank you.
07-05-2022 08:16 PM
Thank you
07-05-2022 11:27 PM
If you successfully purchased one of the 10 Day US Roaming add-ons you'll see it here....
Log in to your account...click on Plan Details...then you'll see My Plan and Add-ons. That's where you'll find the info on the add-on.
As suggested by previous Forum member....if you see the $$ you had allotted for the US Roaming add-on sitting in Available Funds...then you haven't successfully completed the purchase yet.
