Account deactivated despite autopay enabled
Chandelie
My account was deactivated despite autopay being enabled. This has worked fine in previous months. How do I get this fixed?
In an attempt to fix it myself, I just replaced the credit card on file with the exact same one. I still don't have service.
Now I'm wondering if my son's service will also be cut off as it is paid with the same credit card.
I've been a customer since 2016, and I've experienced very few disruption s to my service while I've been a customer.  Yes, the interface is flakey at best, but for most folks who you will never hear from, there are no issues.
95% or more of the posts in this forum are customer complaints.  There are so few good experiences related, you're going to think the worst of the system when it fails.
It is a good idea to treat autopay as a back-up if you continue to have problems going forward with AutoPay.  Top up a couple of days early, and the wait for the renewal to happen.  Removing autopay from running, but keeping the card active, still gives you the discount, but takes away the AutoPay detour.
90-day plans fail less than 30-days if you're interested, and topping up early helps smooth the transition.
mik101
@RobertQc
There's no good excuse for auto-pay ever failing though if the creditcard works-- the programers should be fired if they can't even handle that. This is nothing but a few database lookups, a couple of IF statements and some grade school algebra.
Scammers have no problem processing credit card data, why should a Telus subsidiary?
geopublic
In another post a customer with a similar problem was able to pay using *611 with the credit card on file and got his service back. Might be worth a try.
**Edit:
https://productioncommunity.publicmobile.ca/t5/Announcements/RESOLVED-System-issue-expired-select-cu...
@Chandelie  As for your sons service, just top up in advance. Its usually the auto-pay system that fails, not your actual credit card. So if you pay in advance then you know for sure the account will not be suspended.
RobertQc
@Chandelie  "Simply make a one-time payment from the “Payment” tab in Self-Serve and opt to pay the “Amount Due”. This will cover the new plan cost less any partial payment that was taken. After successful payment, your services should be fully reactivated. If your services aren’t restored, please reach out to our Moderator Team ASAP and they will help get things sorted out. "
If your current "amount due" shows $0, try private browsing / incognito mode or call 611.
If no matter what you try you cannot make a payment with your card you can go to recharge.com and purchase a payment voucher.
If you are still in a "current market plan" you can try doing a one time manual payment and then doing a plan change. Once paid if it still doesn't reactivate you can try the "lost/stolen" trick or add another manual $1 payment. LOST/ STOLEN TRICK HERE Remember to reboot your phone after each step.
Fair Warning. Unfortunately, sometimes auto pay fails. Think of auto pay as a method for public mobile to charge you IF your account does not have sufficient balance. If you have sufficient balance it does not need to autopay, but auto pay is still configured so you get the reward. I highly recommend everyone to top off (by manually adding funds) in advance as this process will prevent the most common and preventable reason that your account goes into suspension with a HUGE pain in the butt complete loss of service.
Dunkgirl
@Chandelie  Try making a manual payment of $1 or clicking the reactivate button
