About the 4GB promotion
alecyeh
I was wondering the 4GB promotion is only for 3 months or we can still have this promotion after 3 months.
And how long will it take for tranferring to PM?
Thanks
11 REPLIES 11
j4y4r
Will do, thanks!
@j4y4r If your payment went through just yesterday, try send a private message to a moderator explaining your situation. Private messaging
If that fails be sure to activate an automatic a plan change for your next renewal date.
JaK
Outgoing calls to the province you are physically in are free, outgoing calls to any other province (including back to your home province if you are out of province) require a LD add-on.
Another way of looking at it, the "local" area for outgoing calls follow the actual location of the phone, the local area for incoming calls stay with the location of the phone number.
syed
Thank you for reply.
a
nd what about outgoing call in same provice to a out province number.
like AB Number in ON
nishufan
Hi @j4y4r
  You can choose this new plan for your next cycle, but you need to renew you plan in your self-services account before Nov. 20.
JaK
Hi @syed;
Lots of other threads going on about this, all incoming calls are free in your home province, all incoming calls require a LD add-on if you are outside your home province.
@syed wrote:
Hi,
with 4GB plan, out country and out province incoming calls are also charged? Like if i recieve any call from US in ontario, i will be charged for it?
bryanbreguet
Not when you are, yourself, in your home province
syed
Hi,
j4y4r
I just found out about this, and unfortunately for me, I also just got charged for another 3 months today! Is there anything that can be done to put me on the 12gb package this 3-month period instead of the next? (in Jan)
ckl
Once you're on the 4GB promotion, you stay on it as long as your account is in good standing.
The promotional period only means you have until Nov to get on this plan.
If you are porting in, it will take around 5 minutes to port in IF everything goes as planned.
bryanbreguet
You can keep it for as long as want. It's just that it'll renew every 3 months.
Transferring is usually very fast. Like minutes or hours at worst.
