06-29-2022 05:05 PM
Hi there, if I want to switch my plan, do I need to wait till next month to start new plan or I can change it immediately? Thanks
07-02-2022 10:20 PM
Thanks 🙏
06-29-2022 05:35 PM
You can change immediately but it will technically cost you more as you will be cutting off current 30 days plan period short.
Ideally, schedule plan change on next renewal unless you really need unlimited minutes or more data.
06-29-2022 05:11 PM - edited 06-29-2022 05:12 PM
It gives you the option:
Change plan now: this allows PM to charge you new plan amount now and start a new cycle today. But remaining days on the old cycle will be forfeited, no partial refund
Change plan on the next renewal date: best option if you don't need the extra data or minute now and you can wait
