02-03-2022 09:05 PM
02-03-2022 11:16 PM - edited 02-03-2022 11:47 PM
@pkaraa wrote:@Subba Are you able to add any other card so narrowing down to this debit visa card.
Is postal code for the card and on public mobile's profile the same?
The postal code used for the billing address and the postal code in the Public Mobile profile do not need to be the same. The billing address (including postal code) for the credit card does need to be correctly entered on the Pubilc Mobile payment page, but there is no link between that and the profile name and address.
02-03-2022 09:52 PM
02-03-2022 09:25 PM
@Subba Were you able to even add the Visa Debit card on the system?
You have added the card and just unable to activate Autopay or you cannot even add the card?
02-03-2022 09:20 PM
Try clearing the cache on your browser then go incognito.
02-03-2022 09:17 PM
Hi @Subba
Accepted payments(publicmobile.ca)
close all Browser and clear cache and cookies,
and try open one Browser inPrivate mode,
or try different Browser and open incognito mode,
re-entered your credit details,
if you enter too many time the system security is will be blocked and not allowed you to enter it
then get in touch with Customer Support Agent (publicmobile.ca) to unlock security,
if SIMon, can't submit a ticket send Private Messages to Customer Support Agent
02-03-2022 09:15 PM
02-03-2022 09:08 PM
Before logging into your self-serve account, recommend following this procedure to avoid the common glitches that sometimes occur with this process:
02-03-2022 09:08 PM
@Subba Did you get any error? Try using incognito/private browsing mode when trying to add the new card.
