08-21-2021 09:06 PM - edited 01-06-2022 03:13 AM
I need help.Please.
Purchased a Sim card to replace telus service.
I've tried everything and yes Sim card is for Canadian service.
Conflicting reviews everywhere, can anyone help. It says no network. I've tried connecting and it just keeps saying try later.
Thanks in advance
08-22-2021 08:25 PM
Thanks Everyone.
I've generated a ticket. Amazing help from everyone.
I'll keep you posted.
08-22-2021 07:41 PM
oh no good..
so you tried to reboot and it is showing No network on top of the screen?
So, you cannot even make outgoing calls?
did you try to open a ticket with PM to see if there is issue with the SIM provisioning? If you have not done so, I think you should..
08-22-2021 07:34 PM - edited 08-22-2021 07:43 PM
Before you called telus did you have any outgoing service on the phone? Did public mobile show up as your network? If there was no service at all then your SIM card did not provision correctly.
There has been an issue with the activation system with a higher than normal amount of sim cards not properly provisioned to the new account. The CSA's can fix this for you but you must initiate contact for this to be done.
Click on the chat bubble at the bottom right corner of your screen. Type in "sim not provisioned upon activation" and "human" and follow the prompts to submit your ticket.
Keep an eye on your private message box the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a message from the moderators. Wait times are currently less than an hour. Responding promptly will speed up service times.
08-22-2021 07:14 PM
can you try to reset network settings on an Android device
or visit HERE
and go Changing APN Settings On Android device
click HERE
08-22-2021 07:12 PM - edited 08-22-2021 07:13 PM
Did you check your status in self service? Try resetting your network settings on your phone and reboot if self service says status is Active.
08-22-2021 07:06 PM - edited 08-22-2021 07:08 PM
@tina_lachapelle wrote:So I was told it would take a few hours for everything to be sorted. Spoke too soon.Number transfered, Telus was helpful with switch but now no network. Sim card status not active when I check status.
Frustrated.
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
08-22-2021 07:03 PM
Frustrated.
08-22-2021 11:06 AM
08-22-2021 10:59 AM
Thanks Everyone.
Called telus port issue number. Telus very helpful with reactivating the entire process. Took some time but was so happy to have my cell running again.
Your community is absolutely amazing. So helpful and I learned some technical stuff that was extremely valuable.
THANK YOU
Instead of leaping, should have researched first. Lesson learned.
08-22-2021 09:15 AM
@tina_lachapelle wrote:I need help.Please.
Thanks in advance
Hello @tina_lachapelle
After activating a Public Mobile SIM card, insert it into your phone and try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Leave the OLD provider SIM card in your phone to accept the PORT via SMS/text.
Once you reply 'YES', insert Public Mobile SIM and follow step above.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
08-21-2021 09:20 PM
This could be it!!
Thanks. I'll give it a go.
08-21-2021 09:19 PM
I did all of those steps. Account says its activated.
I'm not tech savvy but can follow instructions. I've tried adding an apn for PM. No luck.
I've restarted more than once. It says emergency calls only. Can't call or text.
I did read some had issues with existing number transfer. Went from Telus to PM.
Sales guy did sell me and told me he was having issues with PM and his server . Told me to to it online .
Thanks everyone for all your advice
08-21-2021 09:17 PM
if you have activated PM line and your CC got charged, when you put your PM SIM into a phone, it should at least able to make outgoing calls and data
Porting is another issue. If porting not completed, you won't get incoming calls on your PM SIM yet.
During activation, did you requeste porting and provided Telus account info? If so. you should have your Telus SIM still in a phone and wait for a text to come in. Telus would send you a message and ask for your permission to release the line for PM. You need to reply YES within 90 mins. If you didn't get the text, if you didn't reply yes, your port will not complete and you need to call a number to re-trigger the process
let us know if you replied YES to Telus
let us know if you are able to make outgoing calls
let us know if you are receiving incoming calls on your PM line
08-21-2021 09:11 PM
Sorry, yes PM Sim.
I'll try this. Thanks.
08-21-2021 09:10 PM
@tina_lachapelle you are trying to activate a new PM line and port in your Telus number?
what have you done so far? you got a PM SIM card and you went to activate the line at : Activate Your SIM Card Online | Public Mobile ?
your credit card got charged?
you put the PM SIM into a phone? what is showing on the screen?
Give us more info and we will try to help.
08-21-2021 09:09 PM
Thanks in advance
@tina_lachapelle Just to clarify, the new SIM is a PM SIM?
You can try removing and reinserting the SIM, or toggle airplane mode on/off. Also rebooting your phone a few times.
