90 day suscriptions
RW62
Would I still receive 4 dollars per month for friends reward plus reward for paying with credit card? Currently on $39 per month thinking of going the 90 day 39 less 5
@RW62 basically you will get the same rewards per 30 days, ie, during the 90 days, you would earn 3x the rewards.
But keep in mind that when you first switch from 30 days to 90 days, you still have only the 30 days rewards discounts towards the 90 days payment.  But it is correct, because  rewards are earned at the end of a plan cycle.
PM will credit rewards to your account on the last day of the plan cycle.  These rewards will then be used towards your renewal on the following day.
When you move from a 30 days cycle, you have only earned one month worth of rewards, and the 1 month worth of rewards will therefore be applied on your new renewal, in this case, the plan change for your 90 days.
After you changed to the 90 days plan, you will be receiving the rewards as follow:
  • sometime during the 90 days plan cycle, you will get $6 Autopay in one payment
  • every 30 days, PM will credit you the loyal rewards, friend referrals rewards and Community rewards, ie, you will get 3 separate payments in the next 90 days
@RW62  Yes you will continue to earn your $4 rewards every 30 days . So to start the 90 days you only have 30 days 1x rewards to start . After completing 90 days you will have 30days x3 rewards for that following renewal
mojorising
Yes, no changes to your reward system earnings.
