90 day subscription
DDM69
What are the benefits to the 90 day subscriptions.  I am on the $39 / 20GB per month.
Thanks
NDesai
@DDM69 You get the discount and flexibility of using the 90 GB data however you want over the 90 days. However, if you travel or want to suspend the line for a few weeks, you can't do that as opposed to when on a 30 days plan where you can suspend just before renewal.
DDM69
That's what I thought.  Thanks
@DDM69
good...pay upfront and not again for 90 days.  😎
@DDM69
Good: cheaper than regular price
             $39 for 30GB, which is a lot
Good or Bad; you get all 90GB on day 1.
           you can use them anyway you like, 89 GB in first month and 1GB for next 2.
           So, it is not good for kids who tend to spend first and worry later
Bad:  essentially, it is a 90 days contract
