06-09-2023 12:10 PM - edited 06-09-2023 12:10 PM
Getting this error when I try and make a voice call.
“7B1 your phone is not activated on the network.”
can receive calls (says no caller ID) and can text, use data, etc. all working fine. Just can’t call out.
been a customer with the same SIM for 5 years. Worked great until recently.
anyone know how to fix it? Or do I need to open a ticket? If so, do I DM someone in particular?
06-09-2023 01:01 PM
@mig39 happy that it works
06-09-2023 01:00 PM
Well that was quick. I sent in a ticket and they "refreshed" my number (I guess removed it and added it again) and then it started working.
06-09-2023 12:50 PM
Yeah, no outages. Everything else is working fine, and I can receive calls.
I've sent in a ticket 🙂
06-09-2023 12:40 PM
@mig39 - it is good you tried the SIM card into another phone and tested. So I presume the same thing happens. So, that rules out a device issue.
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
If not issues, in your area, you can direct message (DM) 'CS_Agent' or use Chatbot (found in Get Help section or bottom of the community page) to open a ticket to customer support.
06-09-2023 12:21 PM
No, I’m on the $39 plan. Unlimited minutes.
06-09-2023 12:18 PM
@mig39 in this case, please open ticket with PM support via direct message:
06-09-2023 12:18 PM
HI @mig39 are you on $15 plan? did you login My Account and check if you have outbound minutes?
06-09-2023 12:16 PM
Tried rebooting, moving SIM to another phone. Been happening for a few days.
06-09-2023 12:15 PM
@mig39 could be just a temporary network problem
Please reboot your phone first
and make calls by putting a 1 in front of the 10 digits and it should help
