02-28-2023 11:05 AM - edited 02-28-2023 02:27 PM
When trying to call someone, I get the message "7B1 Your phone is not activated on the network"
I can Text, receive text and receive Phone call.
When receiving phone call, it show "Private number" even if it's not a private number
Also I tried to create a ticket but I can't login for some reasons.
Edit: I have
Edit 2: I've contacted support using the link :https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
It look like they where unsuccessful at first and send a ticket so a tech can call me. The problem was solve before any one could call me. My guess is that the port took more then 3h and I was just unlucky. Or maybe they did something in the back and solve the problem without having to call me.
09-12-2023 03:27 PM
hi @brianwoltz
let us know what issue you got and we will help
But this is what @MatGod updated:
t: I have
09-12-2023 03:22 PM
where is 'the main thread" ? I cannot solve and support is not being responsive
02-28-2023 02:23 PM
Hey everyone, thank you all for your help. The problem seems to be solve. I've updated the main thread with extra information.
02-28-2023 12:09 PM
HI @MatGod if you can already receive phone calls, it won't be porting problem
did you try your sim in another phone?
I think you should start with open ticket with CS agent. You said you cannot open ticket , got stuck with verification with My Account, then message them:
02-28-2023 11:59 AM
@MatGod sent you the porting team number. Please check your Community inbox
02-28-2023 11:51 AM
I didn't do a temp number but I should have. If you can send the porting team number that would be really helpful.
02-28-2023 11:48 AM
Sounds like a stuck in port issue .
Will send you porting team number
For live support to fix the issue
Private message . Top of page envelope icon
Additional info on porting
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
02-28-2023 11:34 AM
Yes, from Virgin. 3h ago
02-28-2023 11:30 AM
Did you just ported over to PM from another carrier recently?
02-28-2023 11:28 AM
Every thing work except outgoing call
For some reason when I receive call, it show as a private number even if the number is not private
02-28-2023 11:27 AM
Try turning off your phone and your modem/router off then power both on and reset your network see if that helps.
You can not contact a CS_Agent on this Community.
If you are having trouble login, clear the cache and go incognito on your browser.
02-28-2023 11:26 AM
I already try those step
02-28-2023 11:22 AM
try rebooting your device, resetting your network connections, toggle in airplane mode, on and off, and removing then re-inserting the Sim card in the device.
02-28-2023 11:21 AM
@MatGod you see your phone connected to the network? does data work?
Try to reboot your phone once and see if it helps
if you cannot open ticket with My Account login, you can try to use the 4 digits PIN
or you can message support directly if you are still unable to get via Chatbat ticket:
02-28-2023 11:16 AM
