11-25-2022 05:03 PM
Is it a glitch that allows existing members to sign up.. then boom sorry? New activation only..
11-25-2022 05:43 PM
@dabr @Have a few accounts.. we’ll see.. lol
11-25-2022 05:37 PM - edited 11-25-2022 05:46 PM
@Metal1967 So you're willing to be the guinea pig? Kudos! 👍
Make sure to take a screenshot of the page when the code gets accepted (you might need to cancel the change and redo it) just in case you need to argue and prove your case with CSA's.
11-25-2022 05:32 PM
@dabr I switched one to see the outcome..
11-25-2022 05:19 PM
@dabr Exactly..
11-25-2022 05:18 PM - edited 11-25-2022 05:19 PM
@Metal1967 Honestly, if PM can't input the correct coding to begin with or bother to fix it once customers are openly discussing it, then they should honour this price for existing customers who have scheduled a change to this plan and they deserve the headaches!
11-25-2022 05:14 PM
@Yummy @Since 2018 I get it…….
11-25-2022 05:13 PM
@dabr Here come the headaches…😳😂.. for Pm
11-25-2022 05:12 PM
@Metal1967 wrote:@Yummy It allows you to change and input the code.. ..
Eh... You will get used to PM glitches and learn to love them. 😋
11-25-2022 05:10 PM - edited 11-25-2022 05:11 PM
@Yummy It allows you to change and input the code.. .. I realize what it said.. but noticed lots of people switching..?😳
11-25-2022 05:10 PM
@Metal1967 If it is a glitch, then PM has done nothing to fix it as it's been extensively discussed since the announcement, which I find quite curious..
11-25-2022 05:05 PM
I believe offer did say 'new customers only'.
