$40 plan with 15 g
Salvo
I  Changed my plan  to the $40 for 15g.  On renewal date.   It  was today  and it's still saying $40 5g.
Can someone help me change it
Thanks
Salvo
Thanks 👍. For some reason my plan changed to the $ 40 15g
So everything seems to be good now
Thanks for the fast reply
Great job
Hi @Salvo
which browser you are using?  Click the 3 dots on top, select Incognito Tab or Private browsing.  With that mode, it does not use the usual browser cache
Salvo
I got no idea what Incognito mode is on my cell phone
hairbag1
Try logging in to your account using incognito mode...
Yummy
Did you try one of these remedies:
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Click on little spinner refresh icons lower down.
