03-24-2024 02:21 PM - edited 03-24-2024 04:30 PM
EDIT: Support was able to resolve the issue.
Hi, I recently switched to the $34/month 50gb Canda/US Data and unlimited Canada/US minutes plan. Below is the screenshot of the specific plan I switched to (expired Mar 4).
For some reason, when I check my current subscription it's not the same plan above. It's an unlimited 50gb plan with NO US data or text/calling. The only subscription change I made was from my previous plan to the above one on renewal. Has anyone else experienced this?
03-24-2024 06:02 PM
@colleeno - I just got mine on the 20th of March and it did decide to go with the Canada - US $34 50GB plan.
03-24-2024 02:42 PM
I have seen a few other posts that have had this same situation. My plan was set to change to the $34/50GB Canada-US on my upcoming renewal at that time (which was on March 6) and it was successfully completed. My husband is on a 90-day plan so his is set to change to that same plan on May 27. I wonder if it will actually happen? I do know he will lose his 240GB data gift but he doesn’t use much data anyway.
03-24-2024 02:32 PM - edited 03-24-2024 02:35 PM
@NeelM - Please submit a ticket with CS_Agent:
⬇️Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
Oh and can you make calls to the US? View here: https://www.reddit.com/r/funny/comments/pufag/a_phone_number_to_rick_roll_people_with/
For the number call that... it will play Never Gonna Give you up, and that is a way to make sure that you have US plan.
03-24-2024 02:22 PM
@NeelM Check your payment page se if it says the correct plan details . If not contact support to fix
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
