12-09-2022 03:39 PM
Hello all. I've had the $15 plan for two years now and I used to get 250mb for the plan and 250mb for auto pay. It appears over the last few months the 250mb for auto pay has vanished. Has there been a change from Public Mobile or is there a technical issue here.
Thanks in advance for your response,
Bob
12-09-2022 10:52 PM
@golfball wrote:When I signed up (2020) it said 250mb with auto-pay, but I was immediately given access to the 250mb without enabling auto-pay. Once I did enable it I didn't get any extra.
There isn't supposed to be any extra data on top of the 250MB, aside from a time when Public Mobile incorrectly adveertised the plan as including 500MB for a short period of time.
12-09-2022 08:23 PM - edited 12-09-2022 08:24 PM
12-09-2022 06:56 PM
@Yummy- A long time ago there was wording that caused the misunderstanding. It seemed to clearly say that the plan has 250mb and then with autopay another 250mb. Some people seemed to have gotten it honoured. They have since changed the wording (iirc).
12-09-2022 06:20 PM
@Yummy The accounts are on the old reward system.
12-09-2022 05:09 PM
I do not recall $15 had Ever had 500MB.
'Offer' was 250MB IF you have autopay. Now $15 has 250MB by default since there is no more autopay reward for new customers.
12-09-2022 04:28 PM - edited 12-09-2022 04:34 PM
@bple It seems that the 250MB disappeared a long while ago with auto-pay. It may be due to my account (2+ years) being intermittently and intentionally suspended. Not sure in your case.
12-09-2022 03:50 PM
Some of the wording around this plan once upon a time strongly suggested that there was an additional 250mb available with autopay. I seem to recall some people got it. They would have a total of 500mb. But I think it was rare.
12-09-2022 03:45 PM
An edit notation is always nice if adding further information unless cleaning up for typos/syntax
12-09-2022 03:42 PM
@bple wrote:Hello all. I've had the $15 plan for two years now and I used to get 250mb for the plan and 250mb for auto pay. It appears over the last few months the 250mb for auto pay has vanished. Has there been a change from Public Mobile or is there a technical issue here.
This plan has never required pre-authorized payment to receive the 250MB. 250MB is a very small amount and it would be very easy to use up accidently. Does it not show up if you check immediately upon renewal?
12-09-2022 03:41 PM - edited 12-09-2022 03:41 PM
@bple You still get the 250MB of data with the $15 plan, it's just that it's included in the plan regardless of having autopay or not.
You'll see how much you've used by logging into the account using incognito/private to avoid cached information.
12-09-2022 03:41 PM - edited 12-09-2022 03:42 PM
Some of the promotions do come with an expiry.
12-09-2022 03:41 PM - edited 12-09-2022 03:43 PM
Your still getting that data. It's just included as always.
Try logging into your account using a browser in incognito or private mode first.
Then check to see if you can see the data now.
