$15 100 minute plan available or not?
Neosniffron
Trying to activate the $15 100 minute plan.  Looks like it is no longer available.  Any thoughts?
7 REPLIES 7
xiv
Yes, I agree. Unfortunately, PM does not.
Mir001
xiv, thank you for your info. The plan details only says "100 min Canada-wide calling". The details should have all your words.
xiv
100 minutes is for outgoing calls to canadian numbers. The calls you make to toll-free numbers (1-800 numbers) are free and don't count towards your 100-minute limit.
Incoming calls are unlimited.
Mir001
Does the 100 min for both incoming and outgoing calls?
@Neosniffron
The $15 plan is still there.
try activate again using Incognito mode, or Private mode if yiu are using Safari
XionBunny
I still see it under the 3g plans on the main website, so it is still available.
