Reply
DJN
texting sent not received by other party
texting sent not received by other party until the next day, and all at once. Why does that happen?
Re: texting sent not received by other party
@DJN  you may possibly be stuck in a time space continuum Smiley LOL
Hi
Do they receive from other numbers on time?
I had that problem with freedom mobile and would receive batch of text simultaneously.
Also what is the status of your sms is it sent? Can you see when it was sent and received? Could it be mms that you set when your data was not turned on and then got sent when you turned on your data?
It could be an issue with the receiver's provider.  Who do they use ?
@DJN
Could be network congestion, or possibly a weak signal...
My wife had this problem with Telus on an Ipnone. I always blamed it on imessage and its ability to "Send as Text Message." If she didn't right click and say "Send as Text Message" it would not go. It was mostly happening when she sent something to me, and I have an Android, therefore no imessage.
If you have unlimited text you can try to set that user as always send by SMS. I can get you the steps if you think that might be it.
In your wife's case was it  not sent at all or just delayed for almost a day like in op's case?
No she would get it eventually, but rarely immediately.
Your message made me think of one more thing. She also has an Ipad at home that might have been intercepting the messages. Not sure if that's a possibility?
@ChuckYeah No all iMessages with the same iCloud account should get the messages at the same time as long as there is network (wifi / cellular ) coverage.
