Reply
Re: text msgs not sending / Emergency calls only
What rewards didn't get applied, all or just autopay? @geopublic
@geopublic wrote:
Not a myth. The lost stolen trick does cause rewards to not be applied. In my case rewards have been messed up for two renewals and counting. The only way to fix is by moderator intervention. Avoid this method!
AutoPay and referrals.
Don't all rewards get affected?
Don't know but on the problem account only had AP and referrals anf none of them got applied for two renewals and counting so my advice is do not use the lost stolen trick because is creates more problems then it's worth.
I added $1 to account.....no change.
Did the lost stolen/suspend service.....no change
Called the number went to voicemail.....cell did not ring
@z10user4 wrote:
Thanks for the update. Had you been doing the lost/stolen procedure? Is this first hand experience?
First hand experience tried it on one of my accounts and never again!! Not worth the headache.
Why was lost/stolen being run? ...twice?
nvm. you answered while I was typing.
chuck_grady provided an interesting link. Did you have a look there?
It seems odd that the call would go to voicemail if it was Emergency calls only.
You _have_ already submitted a ticket to the moderator right?
It wasn't it was only done once and since then rewards are not being applied and have to be applied manually by a moderator for two renewals and counting.
@geopublic wrote:
It wasn't it was only done once and since then rewards are not being applied and have to applied manually by a moderator fir two renewals and counting.
Wow. That's a thoroughly reputable first hand account. Thanks
