03-15-2015 07:10 PM - edited 01-04-2022 01:13 PM
mon appareil est défaillant, que faire pour le changer ?
my phone is broken, how can I change it?
03-15-2015 09:19 PM
03-15-2015 07:44 PM
03-15-2015 07:36 PM - edited 03-15-2015 07:38 PM
Hello kadkader,
Most phones have a one year warranty. If your phone is less than a year one and was not subjected to any abuse, contact PM. You will be informed that an envelope will be sent to you, in which your phone is to be placed. You will not be provided with a phone while your broken phone is away. The preceding applies only if you bought the phone from PM. If it is not a PM phone, contact the seller or manufacturer directly, depending upon what your user guide says.
If you definitely need a new phone, there is Staples, Future Shop, Best Buy, Walmart and Costco.
