03-19-2015 10:35 PM - edited 01-04-2022 01:14 PM
03-20-2015 12:13 AM
03-19-2015 10:46 PM - edited 03-19-2015 10:47 PM
If you're an existing customer looking for a replacement SIM card follow the instructions posted here
If you're looking to join Public Mobile you can enter your email address at the BETA page and Public will notify you when you are selected to join the BETA program after which you will be sent a SIM card.
