avatar
LarryH
How can I see my avatar?
10 REPLIES 10
Meemo
-Press the little maple leaf cartoon
-Press 'My settings'
-Press 'Avatars'
-Then you can view your current avatar, or choose another one.
srlawren
@dabr wrote:
@LarryH   Did you accidently select your own post as the solution instead of one of the posters who responded to you?
You should be able to click the 3 dots top right of your post to amend and re-assign the solution 🙂
@LarryH FYI, unless you truly worked out your issue yourself without any helpful replies, it's considered bad etiquette here in the community to select your own reply as solution.  I would suggest you mark the reply from @JoyLuck as the solution, as they answered your original question.  @gblackma also provided useful additional information, so either in my mind would be an okay choice.
dabr
LarryH
thank you so much!
LarryH
Thanks so much for your help.!
@LarryH wrote:
ok, thanks now I read that I can change my email under avatar, but I don't see a settings tab or heading?
Select avatar top right, choose settings, then avatars to change.
@LarryH  top right, next to the envelope
LarryH
gblackma
@LarryH  do you mean the Canadian flag by your name? That avatar? Thanks.
JoyLuck
Top right
You can change too in your settings:
