Reply
Highlighted
Why are my solutions being reassigned? Thanks
For the last 3 months solutions given to me are disappearing. I assume they are being reassigned. Is this happening to anyone else. A couple here and there. But the last 2 days and today was pretty messed up. I left around 12 noon with 338 and came back to 334. And I got a new one too. So , in 4 hours I lost 5 of them. Can't be archiving I only registered here on December 25th, 2019. @Tiana_V  can you explain why this is happening? Thanks.
Highlighted
Re: Why are my solutions being reassigned? Thanks
I never even checked
Maybe
It's possible that people mark it (too soon) one way then if it didn't really work out (after contacting moderators and going through the whole process) so they come back and mark correct one.
BUT this is not likely at all to happen five times in one day (let alone 4 hours)
Is it possible that some posts were taken down completely (then the solutions would go down with it) for some reason?
Highlighted
@gblackma I had a solution I gave to @darlicious in my Account Activation post that I had to re assign today. I only noticed it because I went back to let everyone know it went well. Maybe a system glitch? Or as they were cleaning things up they are removing things...no idea.
Highlighted
Members can change their minds later.  I was anxious to get my first few, but not so much any more.
Highlighted
@Naepalm
Are you saying that the mark was removed and you had to mark it again?
Highlighted
@gblackma
It could be when threads have been merged and then there is only one solution given.
Highlighted
I'm saying wjen I went shopping. I had 338. When I came back it dropped to 334 4 hours later. And that's just today. Somewhere in the past I lost 5 of them.
Highlighted
Black magic? You've been cursed by a witch?
More likely OP changed their mind. 🤔
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
Quite awhile back I had read that some Oracles assess solutions to threads with no solution ever assigned. And also reassess some.
But on other hand you can give a bravo and take it away. Can you take away a solution that you personally gave?
I wonder:
Why doesn’t a thread close/lock when it is given a solution?
When the thread keeps taking responses and a newer response comes along....who can reassign the solution to the better response?
Highlighted
Stuff happens when you turn your back.  Moving post is not my thing.  Lucky my hands are clean.
