Reply
Highlighted
Re: Using phone in the USA
@jonfirlotte wrote:
I would get the international add-on just to be on the safe side, your regular plan may not work.
It's already been established that a $40 Public Mobile plan will not work in the U.S. unless a roaming add-on package is purchased.
Highlighted
Unfortunately it's just renewed... I should have thought of this earlier and paid the $60
Highlighted
Highlighted
Unfortunately, that means that you're stuck with roaming add-ons. The downside of this is how less data is included if you want to spend only $60 this billing cycle.
Highlighted
Stop posting things you are not Sure about.  What good is the international add on if it won't work where the original poster needs it to work. FYI. Any time you are out of the country it's called Roaming
