Reply
Highlighted
Using phone in the USA
I'm on the $40 plan and I'm going to the USA for 2 weeks this month - do I buy the $15 international add-on in order to be able to make calls when I am there? What happens with data roaming?
Thanks, Sarah
Accepted Solutions
Highlighted
Re: Using phone in the USA
Thanks, Sarah
You can consider getting the 10 Day US Roaming Add-on...talk/text/data for $20...or talk/text for $15.You 10 fdays start the minute you buy it so plan ahead. If you buy it at 10pm...that counts as day 1.
PS...your regular $40 plan will just stop working while in US. There's no risk of surprise data overages when you get home.
All Replies
Highlighted
@slhudson23 there are roaming data/text and calling add ons for 10 days at a time, the other option would be to switch to the 60$ plan for a month
Highlighted
Thanks, Sarah
Highlighted
Stay Safe!
Highlighted
You could purchase the $20 add-on which would give you both phone, data, and text.  It is only valid for 10 days from purchase.  Remember when purchasing the add-on you need to purchase and add it to your account.
Highlighted
Thanks, Sarah
If you are able to switch your plan to the $60 plan on your renewal or if it falls within a few day of it to change it immeadiately on your departure day it would give you full coverage while you are there. It would cost the same as the add on but give you a lot more data 2gb as well as 3gb more while in Canada.
Highlighted
Thanks, Sarah
Ensure that you purchase the correct add-on. In the past, people have purchased long distance minutes by mistake. Be sure to take a roaming add-on.
Highlighted
Ah ok so it has to be roaming? I was trying to figure out the difference between '200 min US and Canada Long Distance - $8.00' and US roaming unlimited minutes talk time - $8.00'
Highlighted
@slhudson23  Where does your renewal date fall in regards to the timing of your trip?
Highlighted
I would get the international add-on just to be on the safe side, your regular plan may not work.
