Unused Data carry over to next month
rdeengar
Does unused data get carried over and added to the balance of to next month. If not, it would be nice to carry it over becuase sometimes in a month you hardly use the data that is there in the plan, but in another month there may be a huge requirement for data, and if there is data banked in the account then it will come in handy. Thanks.
2 REPLIES 2
@rdeengar This idea definitely exists in the Public Lab - please do not create a duplicate one! Instead, you can simply search for the existing idea and bravo it for PM's consideration.
PMcNamara16
Unused data that is a part of your plan does not carry over to the next month, but if you purchase a data add-on (i.e. a 1GB add-on for $30) it will carry over until it is used up.
This is an idea you could bring to the Public Lab (Although it is currently there right now; you can go and "bravo" the post there). I personally would love to see something like this as I do not always use 100% of my data either.
