Reply
Transferring phone number from Koodo to Public Mobile
Hello everyone, how can you transfer a number from koodo to public mobile? During the process it stated that I had to make a new number and contact the team. Is there any way I can do it through the self serve account?
Thank you.
KMG
Re: Transferring phone number from Koodo to Public Mobile
Log in to self-serve, and under "My Profile" on the right side, click "Change Number".  It will then give you the option to transfer your existing number over to Public Mobile.
@vish9090- note that if you have a prepaid plan with Koodo, you must get assistance from the moderators in order to do the transfer.  If that's your case...
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
Hello communtity.  I transferred four lines for my family from koodo to public two days ago.  Three of the lines transfered but one line hasn't transferred.  I followed the instructions and got a temporary number and then went to change my number to the koodo number.  But it never transferred.  I got an email from koodo for each line saying the service was cancelled, so from their end the transfer process seemed to go through.  WHen I call the number, it's no longert in service.  I've written three private messages to the moderators over 48 hours and have gotten no reply.  Please help.
@sarahhall1006 unfortunately the mods seem to be a bit backlogged.  As long as you sent them a message with the porting info they should get to it hopefully today.  You seem to be another person who has had the port go through (cancel old provider) but not assigned to your sim.
@Moderator_Team can you let us know if this is a new porting bug?
Hey,
This should solve your issue. I ported over from Koodo, as well, two weeks ago.
1. Login to Self-Serve
2. Go to Plan and Add-Ons > Change Phone Number
3. Click "Transfer a wireless or wireline number from Public Mobile or another provider"
4. Enter your number and click "Check Eligibility"
5. Click the "I am authorized to transfer this phone number" before you do anything else.
6. Fill in the box to the best of your ability.
7. Click Submit and wait (don't press anything else until everything is clear).
This should port your number over without any mod assistance, assuming you're not pre-paid.
EDIT: This solution won’t actually work because the port was initiated by Koodo but got lost on the PM side. This is a job for the @Moderator_Team. It would work if no port was initiated by Koodo and @vish9090 just bought the SIM and manually tried to port. Thanks for clarifying @mimmo!
@Shaheer unfortunately what you suggested won't work as the line on koodos end has been cancelled because the port was initiated and got lost on the on side
Ah, I see. Thanks for clarifying—didn’t know.
Yes.  Initially I followed all those steps and all seemed okay, but the phone number never was transfered.  I got the email confirmation from Koodo that our service has been cancelled.  When I attempted to transfer again, the number was no longer eligible.  It’s been 48 hours.  Do you think the moderator will reply soon?
Sorry, but there's no way for anyone here to know when a moderator will reply to you.  Only the moderators can know that.  But what I will say is that they will get back to as soon as they can.  They don't want customers to wait any longer than necessary.
