Texts from Public Mobile are in french
mab
Hi. All the texts I get from Public Mobile for alerts, updates, etc are in french. How can I change these to english?
mab
It has always been in French. I think I accidentally selected French during activation.
Language choice is made during activation
Did you previously get english and just started to get french now?
mab
Thanks everyone. I've sent a private message to the moderators.
jp2
That is the one I found as well.
I find it odd that they wouldn't have an option for language preferences but I guess they figure that shouldn't change?
will13am
This is the first time this question has been asked that I am aware of.  Anyway, I did a search and this thread popped up.  It looks like you need to ask the moderator team to reset the language preference.  The moderator team can be reached via private message using this link.  Refer to the following knowledge base link for information on contacting the moderator team.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Changing-Language-Settings/td-p/48094
jp2
I would imagine there is a way to change this in your profile settings but I don't see it. You may need to contact a mod
