Reply
Re: Sim card
I installed the sim card and it works. Eureka. Thank you for your help.
Re: Sim card
@totalUser wrote:
@publicjoe wrote:
I waited a day and it's still saying that. A bought it from public mobile.
You will have to contact moderators.
What hapoens when you try to login to selfserve with the credentials you provided during the original activation? https://selfserve.publicmobile.ca/
Re: Sim card
That's great Smiley Happy
Please verify that selfserve was created during the signup. If not you should do it https://selfserve.publicmobile.ca/self-registration/
Login and check your status and balance.
If you forgot your friend's referral code during signup because you did it do many times it's still not too late, you can contact moderators and give them the code explaining that something went wrong during activation. You will get a extra $10.
Also check if you got your $2 for autopay it should show as balance
Welcome to public mobile and enjoy the savingsSmiley Happy
Re: Sim card
Sim may be faulty. Simply return it and exchange it
Re: Sim card
He said that it works. https://productioncommunity.publicmobile.ca/t5/Discussions/Sim-card/m-p/484895/highlight/true#M10460...
