11-02-2016 10:08 PM - edited 01-04-2022 04:14 PM
Hello Community,
I'm looking to setup another account for my daughter. One questions, should I use my name and date of birth (keep in mind I have an account with PM already).
11-02-2016 11:05 PM
Thanks all. So my daughter is all setup with a temporary number.
I was able initiate the port of her number from virgin to PM (recieved a successful port message). But then again it displayed for me when I ported my number in but still needed technical support to work.
I'll check in the morning, hopefully her virgin mobile number is working. If not, I'll tag a Mod to help fix it.
Thank you again for the direction, have a great night.
11-02-2016 10:32 PM
11-02-2016 10:21 PM
You must use a different email address for the 2nd account; only 1 phone number per account.
Everything else can be the same.
11-02-2016 10:14 PM
I believe that receiving support will be easier if the account is in your name since you will be the one contacting Public Mobile support.
11-02-2016 10:11 PM
Okay thank you. I was more thinking of it being confusing if/when I need support on her account.
Will I still be able to administer the account and recieve support? (sorry for the newb question).
11-02-2016 10:08 PM - edited 11-02-2016 10:12 PM
To be honest, it doesn't really matter as Public Mobile is prepaid. The birth date is not a required field and doesn't need to be filled out to sign up. Although, If you are porting in a number I would use the phone number's owner's name to prevent any problems in porting. If you are porting in a phone number that's under your name, I would set up the account in your name, then after everything is done and set up, you can go to "edit profile" in the self serve and change the name and contact info to your daughters name and information.
