Retaining my number
winson0228
Hi
I'm going to be out of the country for a month. If I don't pay for a month, would I still be able to keep my number when I come back and start a plan again?
Thanks
SD08
@mclyin wrote:
@kav2001c wrote:
@winson0228 number will be fine up to 89 days
You need to make a payment before account deactivate
Would one still able to retain the existing plan if after a period of inactivity (within the 89 days)?
@mclyin
Yes.  If you change plans, you'll only be able to select from those currently available, and you won't be able return to a previous promo plan.  As long as you don't make any changes, you can keep renewing the same promo plan, even if you let it expire for a while.
mclyin
kav2001c
Your account is fine if not active for one month.  But remember to reactivate it again when you come back. 😄
SD08
Yes, you can let your account lapse by turning off autopay.  You'll have up to 89 days after the expiry of your current period to reactivate on the same plan and same number.
