Re: internet not working
Trinityangels
My internet is not working on my note 3 please let me know why thanks
2 REPLIES 2
ky01
Has your internet worked prior or is this your first time setting it up on the phone?
I would first make sure you have the correct APN settings, here is a topic with the information you need regarding setting up APN:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Good luck!
Luddite
@Trinityangels You have posted to an old thread. In future you will have more assurance of help by creating your own topic on the forum  (which I have done for you today).
Here's a rather long checklist on this topic:
- connects with wifi?
- cellular data turned on?
- confirm data is included in your plan and not used up
- if dual sim use LTE/3G slot
- is it all apps that use data or just the browser not connecting?
- toggle airplane mode off/on
- remove sim for 5 minutes, then install and reboot
- go to settings, then general-profile and delete any profiles
- check network is not set to 2G; use auto, 3G, or LTE
- check for operating system updates
- APN settings correct? Public Mobile
- delete current APN, and re-enter settings
- remove any VPNs
- reset all network settings; you will need to add back wifi passwords after that.
- try sim in another phone and a good sim in your phone
- phone make/model? In case someone has some specifc ideas.
- LAST desperate measure when all else fails; erase all data and restore phone to factory settings
