Reply
Highlighted
Problems with calling
My dads plan has unlimited talk to Canada and the US but a lot of the time he tries to dial a number and it says he doesn’t have talking privileges. After trying multiple times it sometimes works.
Sometimes he gets a message saying he can’t dial long distance.
This is is an issue as he needs to be in contact with his doctors. He can still get phone calls fine.
Please help.
Accepted Solutions
Highlighted
Re: Problems with calling
@henry2018 if it does not show up anymore in your data and addon section it means you used all your outgoing minutes its only 5 bucks for a 500 min add on and they stay on your account until all used up
All Replies
Highlighted
Try dial the +1 infront of your number. this helps me limit the message when dialing.
Highlighted
@HumbleBee
Which model phone does your father have?  Any issues with text or data?
You could try the SIM card in another unlocked phone.  To help determine whether it is a hardware issue/setup versus PM service issue.
Highlighted
Please help.
As long as you have Canada & US calling plan you won't see any added costs for calling long distance...while you are in Canada. As suggested by @seyvoutychan , try dialling 1 before area code. Ignore recorded message that "long distance rates may apply".
If problem persists and your calls still won't complete, then contact moderator for their input. Click this to message them
Good luck.
Highlighted
Please help.
@HumbleBee  Check the signal strength for a weak signal. Also edit contacts and add +1 in front of the numbers.
Highlighted
Please help.
@HumbleBeeI added (1) infront of area codes on all my contacts
Highlighted
I have same issue
Highlighted
@HumbleBee
You could have your dad try the "lost/stolen phone trick" to re-provision his plan features:
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start phone to provision your account again. i.e. enable all features of your plan again.
Highlighted
I did that. seems does not work
Highlighted
@henry2018 Hi are you on the 10 or 15 dollar plan did you possibly run out of minutes?
