Porting Issues
ppachai
I activated my account yesterday, and received confirmation that my number had been ported from Freedom.  I can make and receive calls but am receiving no data.  Can't figure it out.  I am using a LG V20 which is unlocked.  Can anyone help?
Thanks.
7 REPLIES 7
Mary_M
Retraité / Retired
Retraité / Retired
Hey @jamiedowner,
I've responded to your private message. It seems like the port did not properly process but I was able to get it going ! Please view your messages for more details 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
jamiedowner
i have sent a msg to a mod and no reply yet so i have to post here i got set up with PM yesterday everything works now but my number hasnt ported over i can call out send text but i can not get incoming calls i really need to get this fixed
and when i call out its shows the number i ported over
ppachai
Yes.  Thanks.
imm1304
does this mean that the factory reset helped?
ppachai
Thanks.  Tried that but no success.
Acekiller
If you have configured the APN and restart your phone, the next step would be creating a back up and then factory reset your phone.  A lot of user (myself included) had to factory reset the LG phone (mine is a LG G4) to get data to work.
imm1304
Hey @ppachai!
Welcome to PM!
You will need to manually enter the APN settings for data to work.  Some phones don't automatically configure APN settings.  Here is how you can do that:  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-And...
