Reply
Highlighted
Plans 30 days vs 90 days
Hello all,
I am curious what the thoughts were on having a 30 day vs 90 day plan. Are there any notable benefits with the 90 day plan? At this point I am completely happy with the plan I currently have (30 day plan), but am curious if it might be worth switching to a 90 day one.
Thanks
Accepted Solutions
Highlighted
Re: Plans 30 days vs 90 days
No financial advantage on all most all of the 90-day plans.  Most work out to be the same cost as 3x30-day.
If you have a data plan, you use the entire amount of data over the entire 90-day period.  If data on 30 days is 1GB, the 90-day equivalent is 3GB.  It is not per 30 days reset, it is all 90 days.
You will make fewer payments in the year (4 or 5) as opposed to 12 or 13 (depending on dates of renewal each period.
All Replies
Highlighted
