Phone problem
Courville89
Why can I not send or receive photos in text
12 REPLIES 12
MJ23
Have you tried restarting your phone? Some times it works.
cheers.
@Jessica_T, MMS is affected by the SMS limit, as MMS is still driven by the SMS/MMS.  If the 50 outgoing messages have been reached between SMS and MMS, then no outgoing MMS or SMS will be sent.
In the case of using data-based messaging apps, such as iMessage for iPhones, or WhatsApp, these services use strictly 'the data' bucket, and have no effect on the SMS/MMS count.  ****Except for an iMessage sent SMS.
Jessica_T
@Alex888 wrote:
Have you checked your account to see if you hit your text limit?
@Alex888Text limit doesn't matter for incoming nor does it matter for MMS. Picture messages are no longer standatd text they are converted to MMS. So text limit is not an issue.
Alex888
Jessica_T
@Courville89 wrote:
Yes
@Courville89Yes to APN confirmation, or just that data is enabled?
Triple check the APN settings, check very carefully. If possible show screen shots of your APN, it seems sometimes people add a space first or remove a decimal place or mess this up. It has to be exact.
 APN: sp.mb.com
 Proxy: Not set
 Port: Not set
 Username: Not set
 Password: Not set
 Server: Not set
 MMS proxy: 74.49.0.18
 MMS port: 80
 MCC: 302
 MNC: 220
 Authentication type: Not set
 APN protocol: IPv4
 APN roaming protocol: IPv4
 Bearer: Unspecified
 MVNO type: GID
 MVNO value: 4D4F
Courville89
Yes
@Courville89 wrote:
Yes like for the data and stuff? My data is working so is texting and phone
The dumb question...is your data mode on?
Data working and texting working doesn't necessarily mean that things are set up correct to be able t use MMS.  MMS has specific settings within the APN that need to be configured. If the MMS portion of those settings were missing or incorrect, your data would still work.
Jessica_T
@Courville89Check again, APN can be configured to let data work, but not MMS. Texting is not MMS. Texting is SMS. SMS is not picture messaging. Phone is none of the above.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Courville89
Usually, if you are unable to send an MMS type message, this usually means that your APN settings are not set correctly. https://apn-canada.gishan.net/en/apn/public-mobile
Jessica_T
@Courville89Did you configure your APN?
