06-17-2018 02:04 PM - edited 01-05-2022 04:56 AM
Hi,
just wondering if anyone can help. Got the sim card activated yesterday. Out going calls are working but not receiving incoming calls.
06-17-2018 02:49 PM
@DPGJ1 as mentioned if portiong (and has been longer than 2 hours) contact mods links are above. but include
If you have a Porting issue, please also include:
06-17-2018 02:44 PM
@DPGJ1, Did you port(transfer) in an existing number? If so, and you transfered from a cellular carrier, then something probably went wrong with the transfer. If you took a new number, then this deffinitely should not be happening. In either case, you need to send a private message to the moderator team and have them investigate. If you are transfering from a land line or a VOIP line, then transfers can take much longer (several days, up to a couple of weeks).
If you need to contact the moderators, click here to send them a private message. Moderators' hours of operation are M-F 9AM-9PM(EST) & S/S 9AM-7:30PM(EST)
Information regarding the moderators team can be found by following this link.
If that doesn;t cover your situation, then plase provide additional details.
06-17-2018 02:16 PM - edited 06-17-2018 02:24 PM
@DPGJ1 wrote:Hi,
You can try:
- restarting your phone
- powering off your phone and removing the SIM, then re-insert it
- go into your phone's Cellular network settings and manually selecting Public Mobile as your Network Operator
06-17-2018 02:13 PM - last edited on 06-17-2018 02:32 PM by NDesai
you need send a private message Click here
In your message put it, please include .
- your account number , if you have it , or email address .
- your phone number and 4 digit PIN .
- your name .
- Detailed explanation of specific
- them can help you a lot 🙂 nice team service
Good Luck
