12-22-2018 11:33 AM - edited 01-05-2022 06:21 AM
I have two SIM with Mobile Public. Now my phone could not send any MSM messages, only received messages, I have to switch with my son phone the problem is still not send message. What will I do now?
12-22-2018 12:35 PM
Log into your account then post a screenshot of your "Data and Add-ons"
12-22-2018 11:46 AM
@tphung5 wrote:Yes, I am on $10 plan. I'm check my account so far my message only 1/50 text. I am texting with SMS.
What kind of phone is it? Maybe there's some kind of block or permissions set. If it's an iphone maybe it's set to use iMessage and not SMS.
12-22-2018 11:43 AM
12-22-2018 11:36 AM
Check which plan you have as you might have run out of texting if you only have the $10 plan.
12-22-2018 11:34 AM
@tphung5 wrote:I have two SIM with Mobile Public. Now my phone could not send any MSM messages, only received messages, I have to switch with my son phone the problem is still not send message. What will I do now?
You made it. Good to see you here.
Maybe the MSM has blocked you 🙂
Do you mean regular SMS or MMS?
Are you on the $10 plan? If so maybe you've used up the texting allotment.
