My phone calls go directly to voivemail what is the problem
aloder
Set up a phone now all my phone calls re going to voicemail
16 REPLIES 16
mundler
Check in your phone settings ("About Device -> check SIM status" is the likely buttons to click) to confirm that your phone is a) on the network and b) shows the correct phone number. I found that I couldn't get through to my dad's phone number until I changed his contacts profile within his own phone to recognize that he was this new phone number and after rebooting the phone, he now receives phone calls. Hope this helps!
aloder
Yes I did. I gave my phone number old account number and PIN number.
Carld123
@aloder wrote:
Yes I am a new customer. Not sure what to do. To get my phone working
@aloder
Earlier in this thread a moderator replied to you asking you to check your private messages..did you check and respond to the message?
aloder
@aloder wrote:
Is there a number I can call to get my problem resolved.
Since you said yesterday that you set things up, I'm going to take that as you are a new customer. Sorry, but you cannot call in.  All customer service contact must be done by sending a private mesaage to the user Moderator_Team
aloder
If you requetsed a phone number to be transfered to Public Mobile, this could mean that the phone calls are going to the carrier of the service that you are trying to leave.  That would happened if that sim card has been removed and is in a powered up device.
If that's not the case, calls going to straight to voicemail can indicate a few things.  Those include poor/spotty signal/coverage, a fluctuation in network conditions (capacity, or cell site "breathing" - a shrinkage of coverage area that can occur when many people are connected to a cell site), or a Public Mobile back-end routing issue.
On your end, this could be caused by a defective device, call management (blocking) settings, DND settings, the wrong network being selected or wrong network type, or pretty much anything that could cause the phone to not be connected to the network (included being turned off).  I'm aware that you know that you phone isn't turned off;  I'm just stating possible reason for calls going to voicemail that could happen to anyone.
Did you see the private message the moderators send you??? @aloder
aloder
Call forwarding is not on
CS_Agent
Customer Support Agent
Hello aloder,
Thank you for reaching out to us we will be more happy to help you.
The moderator team sent you a private message regarding your question.
Please check your messages !
Looking forward to hearing from you
Best regards
aloder
How do I part  my number
Dunkgirl
@aloder wrote:
Just set up my wife's phone today
@aloderMore details please. Did you port her number in, or get a new number? Is it a new phone? Is it blacklisted? Is it locked? Does it support the public mobile network? Can you call out? Do incomming texts work? Are you connected to public mobile network? Is do not disturb mode on? Have multiple people tried to call you? Details. Details. Details. Details. Details. Details. Details. Details. Details. Details. Details. Details. Please.
Murco
Maybe a weak signal resulting in network disconnects and call forwarding.  Is call forwarding on?
aloder
Carld123
@aloder
Did you port a number to PM or a new number activation?
Dunkgirl
@aloderDid you just join public mobile? If so did you port a number in, or get a new number? If not has your phone ever worked with public mobile? Is it a new phone? Can you call out? Do incomming texts work? Are you connected to public mobile network? Is do not disturb mode on? Have multiple people tried to call you? Details. Please.
