Reply
Re: MMS - With data turned off
OK, I'm going to need some help to turn this into a solution if it can be. I have a MOTO G3 and I adjusted my APN settings to this to get the desired results. Pay special attention the the bold type. However, it REPLACED my original APN settings. Is there any way to get both of these to stay as options under APN and switch back and forth.
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: mms
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
The only problem is it replaces the regular APN settings as shown below.
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Does anyone know how to make both of these avalable and just switch between them, or is it possible?
@chuck_grady  don't have time to test at moment..but I wonder if MMS was put FIRST  in this line default,mms,agps,supl,fota,hipri
@shafarrah
Procedure
  1. Open Android Messages.
  2. Tap the 3 dots in the top right corner.
  3. Tap Settings.
  4. Tap Advanced.
  5. Make sure Auto-download MMS is toggled right, it will turn blue.
  6. Make sure Auto-download MMS when roaming is toggled right, it will turn blue.
I like @chuck_grady's idea. Only keep mms for APN type.
If you ever need to use data, change it to default, mms. You don't really need the other ones.
It did not work for me, but would appreciate any thought you might put into it. I toggle my data on and off as I only have 1GB. This would really help me too.
I'm gonna try this too.
@geopublic wrote:
@shafarrah
Procedure
  3. Tap Settings.
  4. Tap Advanced.
On Android 10 not sure about other versions once you turn data off an option appears on the same screen Send MMS when data is off. Once you select that option MMS works without data having to be on.
@geopublic wrote:
@shafarrah
Procedure
  3. Tap Settings.
  4. Tap Advanced.
Checked and auto download mms was already blue. Still need to figure a solution without turning on data.
@geopublic  did not work for me@@. "Auto download" was already blue..turned on the roaming one did not wor
HOWEVER I did notice something cool...in that "Advanced " section.
One option said "Sim Card Messages".
When I clicked that it showed me my original 4 digit pin when I signed up with Public Mobile.
It also showed my current 4 digit pin.
Not sure what PIN it is as I found out today..account pin is different then voicemail pin unless manually changed .I guess way back I manually changed pin so they match....
What pin do you guys think it is? And do you guys see the option in advanced section "Sim card messages"??
Maybe it could be helpful for future people that say they forgot their pin instead of directing them to Moderators??
