Reply
Keeping the same phone number and plan after switching SIMs
Hello,
I'm going to Australia for a month or so. I'd like to get a new sim card with a plan for over there.
My question is: When I switch back to my old SIM, will I keep the # and plan I previously had?
If not, what are my options?
thx a lot
Re: Keeping the same phone number and plan after switching SIMs
@biberboris, As long as it is LESS than 90 days from the time your account goes into suspension(end of payment period), you can use the old SIM & number.
Based on your trip length, you should have no issues.  If you are on auto-pay, you should disable it, so that you do not pay extra whiile you are gone.
Sweet, thanks for the swift response!
