Reply
Highlighted
Re: International Roaming
@jp2 wrote:
If your plan includes calling to the US I think you should be able to forward to a US or Canadian number but I'm not 100% sure
And @cobb87 too!
Unless something has changed since this post it's still not possible to forward to a US number:
Call forwarding to US phone number
Highlighted
@koimr1 wrote:
And @cobb87 too!
Good catch
Highlighted
@koimr1  On a recent trip to South Africa via Hong Kong, employing Wifi along the way ( at various hotels, coffee shops, etc), I was unable to successfully use Fongo to complete a call.    I modified the various Fongo settings as suggested in their help section but all to no avail.  Accordingly, I would personally be wary of recommending Fongo as an exclusive source of contact in select parts of the world.
What did work really well, at least for placing calls outbound, was using Google Chat Hangouts.  Before leaving, I added my Canadian cell as the outbound calling ID.  Thus anyone I called could see it was me and not some 'unknown' number which might be ingnored.   Incoming calls are a different matter though so an alternative plan would have to be arranged.
WhatsApp might be a good alternative as suggested above.
edit: Meant Google Hangouts.
Highlighted
@skifan wrote:
@koimr1  On a recent to South Africa via Hong Kong, employing Wifi along the way ( at various hotels, coffee shops, etc), I was unable to successfully use Fongo to complete a call.    I modified the various Fongo settings as suggested in their help section but all to no avail.  Accordingly, I would personally be wary of recommending Fongo as an exclusive source of contact in select parts of the world.
What did work really well, at least for placing calls outbound was using Google Chat,  Before leaving, I added my Canadian cell as the outbound calling ID.  Thus anyone I called could see it was me and not some 'unknown' number which might be ingnored.   Incoming calls are a different matter though so an alternative plan would have to be arranged.
Oh that's too bad. I was able to use Fongo via both wifi and local SIM data last year in Germany/Austria/Hungary/Czech Rep without incident.
If the other choices worked then great! More options to be considered! 🙂
Highlighted
 That's actually where I'm headed, South Africa. 😛
Also, I just found out that you can purchase a Canadian number on KnowRoaming under the 'purchase service' tab. It's only $3. At least I have the call forwarding figured out now.
Highlighted
SA is an awesome place to visit....although one does have to keep one's security in mind.  Keep your passport on you at all times.....if it gets lost or stolen....big problems.
FYI: As for purchasing a local SIM:
Be aware of something called R.I.C.A. which is a regulation enforced by the Government of SA.   Those who wish to purchase a local SIM will, at the time of purchase, need to supply their passport and proof of where they’re staying during their time in SA.  This is relatively straightforward if you’re staying at a formal place of accommodation; simply print proof of your reservation on a letterhead. However, if staying with friends or in informal accommodation (like a house swap), you’ll need an affidavit from the local property owner or tenant stating that you’ll be residing temporarily at the said address.
Highlighted
There is no plans as of right now that include international roaming
Highlighted
ooooo, how did you do that? Didn't think we could in Canada for G Hangouts...
Tags (1)
Highlighted
@Moogie how did who do what?  You didn't really give much context here.  You didn't think we could do what for Hangout in Canada?
Highlighted
I was thinking the same thing
..how did who do what?
..why did they do that?
..and can I do the same?..😀
