03-07-2015 08:11 PM - edited 01-04-2022 01:11 PM
There's no number that I can use to actually speak to someone, how do I cancel my service and get my money back?
03-08-2015 03:39 PM - edited 03-08-2015 03:47 PM
Only SIM setup that should be done is through an activation process, following poster it was already been done
03-08-2015 03:34 PM
03-08-2015 02:30 PM
Check on PM compatibility site if phone has not been declared lost, pull sim, power cycle, reset all network settings, restaure iphone using latest itunes version, update to latest ios, if none helps, try sim on different phone.
03-08-2015 11:27 AM
Hi @NR23 - Please ensure that the phone you're using uis compatible with Public Mobile. Also send us a Web form to look into your account set up by going to Contact Us and selecting Email Away.
03-08-2015 01:28 AM
03-07-2015 11:03 PM
03-07-2015 10:32 PM - edited 03-07-2015 10:39 PM
I didn't do the set up myself, I went to one of the PM stores that got shut down and was re-opened as an independent seller.
When the SIM was put into the phone, it said no service.
So far I've been told to try changing my number, taking out the SIM waiting a few minutes then putting it back in, shutting it on and off, and switching it on and off airplane mode. Nothing has changed.
03-07-2015 09:57 PM
03-07-2015 09:36 PM
03-07-2015 09:07 PM
It's the unlimited talk and text plan.
03-07-2015 08:37 PM
