Reply
Highlighted
Re: I got scammed!
@88cranston wrote:
Also to port a number don’t you have to have the PM account number and name address etc?
What about police or CTRC contact too.
CRTC won't take this case. Disputes need to go to CCTS.
Highlighted
Re: I got scammed!
What's so disappointing is that PM warned me someone has request to port the numbet and I clearly said I never made such a request. I also said this could be a scam.
They clearly had time to decline the porting request yet they just let this happen and won't do anything to fix the problem.
So disappointing.
Highlighted
Re: I got scammed!
@88cranstonThere is no yes to answer to. The Public Mobile message is informational.
Highlighted
Re: I got scammed!
@elnino82
At this stage report to: http://www.antifraudcentre-centreantifraude.ca/index-eng.htm
Make sure your banks know your number has been compromised. Any account that uses your "old phone number" as verification will need to be reset. Do it ASAP because you are liable for any amount stolen from your bank account!! reference here: https://www.cbc.ca/news/business/banks-deny-compensation-online-fraud-security-1.5322982
Bell is the most common method to SIM jacked because their SIM cards only cost $4 and their smallest plan is equally cheap.
In the future, as with anything Public Mobile make sure you have a back up plan. DO NOT use your phone number to authenticate EVER! Use an Authenticator app or a physical key like a Yubikey for your 2FA needs.
Unfortunately if you want to stick with Public Mobile, you will need a new SIM card and email address to attach to your account.
Tags (1)
Highlighted
Re: I got scammed!
@cellphoneuser1CCTS doesn't handle SIM jacking. Besides they only accept disputes that had been resolved.
Highlighted
Re: I got scammed!
I don't agree. If the port out was unauthorized, Public Mobile should have declined it. There must also be a way to reverse a port.
Highlighted
Re: I got scammed!
@cellphoneuser1  @elnino82  @GinYVR  There must be a procedure for this...is it not unusual that pm sent out the questioning text? They must have already thought something was suspicious as who else has gotten a text from their provider while porting out their phone number? I've never heard or seen it mentioned ever in the community "You may recieve a call or text from your provider confirming your choice to port out your phone number."  @elnino82  What number did pm text you from? There is obviously a case of fraud here as it's an unauthorized port and it's important that both bell and pm take this seriously...the onus is on them to do so and if necessary @Alan_K  should have this on his radar. Unfortunately when it comes to local police this kind of fraud is very low priority and other than taking a report there is very little they will do.
Highlighted
Re: I got scammed!
@cellphoneuser1CCTS' mandate is to settle disputes between consumer and the telco. If the complaint is defined as "out of scope" the commissioner will just reject the complaint then there will be no recourse. Best to read up on their procedural code.
Highlighted
Re: I got scammed!
So disappointing.
The porting process is automatic.  All customers have access to the porting feature.  There is not much that Public Mobile can do to pre-empt this.  After the fact, an unauthorized number port can be investigated and potentially corrected.  What is strange to me is that anyone would even attempt this.  There is a cookie crumb trail leading right to the door of the perpetrator.
Highlighted
Moderator
Re: I got scammed!
Hello there!
I will be happy to help.
Before we get started, I will need you to click on the link below and use SIMon and create a ticket.
https://www.publicmobile.ca/en/on/get-help
Bogdan_S
