How to reach out to PM in regards to usage
osama49
In my account overview , it shows that I have used 3 GB since I joined PM on Nov 16th which does not seems to be right, I use wifi when I am home, who do I need to contact from PM to have them check it out?
When I checked my usage history, total used data is much less than the 3 GB.!!
Any help is appreciated.
Thanks
20 REPLIES 20
UDP7
@osama49 Every carrier is different. Signal is different, so it may activate differently.
jheili99
@osama49 i would say that the data displayed within your account should be very accurate and the problem has more likely to do with some phone settings.... i doubt that PM hires people to monitor data usage just for the purpose of manipulating it to "steal" data from users... highly unlikely... i'm with PM since 4 months now, and my data usage is pretty much bang on on all 3 of my lines using iphones 5s, note 5 and s7 edge....
cheers
@osama49, are you getting all of the data?  It may be several pages of information.
its not a great tool for the task, but it is accurate.
@pchan, nice thought on the zero-rated options from other providers. That totally could be the answer.
osama49
@stonechucker
Mine showing
3083.152  /  12288 MB
When I add up the mb in data usage coulmn in usage history, it is less than 1 GB
pchan
Ok. At the time the usage report says your using data do you remember what your doing? The only other thing I can think of are backgound operation such as pulling email or your listening/streaming music and/or it is synching across You wouldn't happen to have SPOTIFY ... free ($$$ and data) on Fido for certain plans, but not on Public mobile.
@osama49,
i see the following wing in the same place.
6GB Data
2425.156 / 6144 MB
Meaning I'm about 2.5/6 GB on my plan.
osama49
@ryanwoo
The usage report , which I ran from view usage history seems to be correct, but when I go to my account, overview, My-Add-ons, under amount used, I see it is 3 GB, but usage history shows much less than that, If usage history shows the correct usage then I have no concern.
osama49
@UDP7
Yes, I have the Smart network switch on. but I have it on even before I swithced to PM from Fido, and I wasn't exceeding my monthly 1 GB limit.
osama49
pchan,
I did review the usage history, and added up the MB in data usage column and the total of MB is the equal to the usage showed in the account overview page.
ryanwoo
Almost all time the carrier side usage report is correct.
pchan
When you logon there's a button to change your plan, right underneath is a View My Usage link. CLick on that and it will give you a session by session of your data usage and call usage.
jheili99
@UDP7 actually thgere is a feature on android called "data boost" which let's both wifi and data run at the same time.... so let's say you watch a movie and believe it to be wifi, you probably also start using/burning up data as well... i usually turn data off when i'm home....this way i know for sure....
cheers
UDP7
@osama49 There's an option on Wi-Fi that automatically switches between Wi-Fi and mobile data. Maybe you have that on. Other than that, I'd just private message a mod about it.
osama49
@Luddite
What if the usage history is not correct, who do I need to reach out?
osama49
I tried to download it from goolge play and getting a message that my device isn't compatible with this version
osama49
I have Samsung note 3
You may want to track your actual usage more carefully; for example
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/IWIK-s-quot-Data-Witness-quot-for-Andr...
UDP7
@osama49 What phone are you using?
magical
You will probably have to wait till your next billing cycle to find out anything or get support!
You are dealing with PUBLICNOSERVICEMOBILE here. Right now there is a 12+ day backlog, so you might get lucky with a answer by xmas.
If you are on the 12GB plan you won't run out till the end of 90 days..
But don't expect anyone here to help for a long time.
Enjoy.
